Look at csp file
tkroeker
Look at csp file
Post by tkroeker » Fri Oct 24, 2014 10:45 pm
Can someone tell me if I am on the right track from a csp file? If so how do I post one?
Thanks
Re: Look at csp file
Post by dlr » Sun Oct 26, 2014 10:12 am
The csp file in WinPCD includes the file names and full path to them, but they are local on your PC. Someone would have to also have your measurements and set up to match or manually import each one first to recreate what you have. You won't get many hits on this sub-forum and are unlikely to get someone to spend the time required to replicate your setup. What you should do is post in the General Speaker Building sub-forum, but not csp files. Post window captures or output files. You can save files of the graphs using the right click context menu save option. Post those with info. You should also use the resources listed in the PE forum Speaker Building Bible. Search the threads and follow what others are doing, you'll learn from them.
tkroeker
Post by tkroeker » Sun Oct 26, 2014 3:06 pm
Very helpful...that is what I needed. Thanks
